campingone10
Nov 16, 2015Explorer
Repairs last visit.
Oper Description Quantity Unit Price Value
0010 HALL WINDOW LEAKING / REPLACED RU 0.500 H N/A 0.00
HALL WINDOW LEAKING / REPLACED RUBBER AND TESTED
8181 SEAL WDW 1 BLK VINYL 7.000 FT 0.00 0.00
0020 WATER TEST AT BELMONT FOR ROOF CA 1.000 H 0.00 0.00
WATER TEST AT BELMONT FOR ROOF CAP LEAKS / TESTED -NO LEAKS FOUND AT WATER BAY
DURING TEST
0030 RATTLE UNDER DRIVERS SIDE / LUBED 0.500 H N/A 0.00
RATTLE UNDER DRIVERS SIDE / LUBED SUSPENSION BUSHINGS
0040 ENTRANCE STEP NOT WORKING / MAGNE 0.200 H N/A 0.00
ENTRANCE STEP NOT WORKING / MAGNETIC SWITCH BAD / REPLACED MAGNETIC SWITCH
2544 SWI DOOR MAGNETIC CLOUD 1.000 EA 0.00 0.00
WH
0050 STEP MOTOR BROKE / REPLACED 0.500 H N/A 0.00
16684 STEP DBL CNV KIT FOR 1.000 EA 0.00 0.00
903209000 KW
0120 ROOF LEAK / REPLACED CAP RAILS LA 22.000 H 0.00 0.00
ROOF LEAK / REPLACED CAP RAILS LAST SUMMER AT DEALER / REPLACED SKIN
1660 SEAL A/C 14X14 2.000 EA 0.00 0.00
1156 VENT RF 5 BLK VAC-U-JET 1.000 EA 0.00 0.00
5866 ALPHA WH SEALER SELF 2.000 EA 0.00 0.00
LEVELING
28722 SEALANT SIKA 221 AL GRA 20 14.000 EA 0.00 0.00
OZ SAU
5536 ADH SILICONE SELF LEVEL 1.000 EA 0.00 0.00
BRIGHT WH
5535 ADH SILICONE CLR 10.2OZ CSL 1.000 EA 0.00 0.00
616 GUTTER SPOUTS-PW R 1 1.000 EA 0.00 0.00
615 GUTTER SPOUTS-PW L 1 1.000 EA 0.00 0.00
5001578 LOXCREEN 16FT ART BLK SM 16.000 FT 0.00 0.00
CVR
4254 RAIL 20FT ARCTIC WH AWNG 38.000 FT 0.00 0.00
15931 TRML BUTT GEL FILLED INSUL
14 TO
50.000 EA 0.00 0.00
35693 ADH STA PUT SPRAY
POLYSTYRENE FOA
1.000 EA 0.00 0.00
11857 SHT LAUAN 1/4 VINYL FOAM
48X99
3.000 EA 0.00 0.00
7393 ANTENNA AM/FM 1.000 EA 0.00 0.00
7281 CONN ST STL FOR ANTENNA 1.000 EA 0.00 0.00
7358 SPRING ST STL TRUCKERFOR
ANTENNA
1.000 EA 0.00 0.00
7359 CB MNT BRKT ST STL 1.000 EA 0.00 0.00
8025 BRKT TRAVELER 3.000 EA 0.00 0.00
8490 ALG SKLT CVR LARGE 1.000 EA 0.00 0.00
5535 ADH SILICONE CLR 10.2OZ CSL 19.000 EA 0.00 0.00
BRIGHT WH
19.000 EA 0.00 0.00
29926 CAP RF 462X99 1/2 1.000 EA 0.00 0.00
4254 RAIL 20FT ARCTIC WH AWNG 40.000 FT 0.00 0.00
0121 $36.99 ALCOHOL WIPES 1.000 H 0.00 0.00
0130 WATER DAMAGE INTERIOR / WATER ON 14.500 H 0.00 0.00
WATER DAMAGE INTERIOR / WATER ON COUNTER TOPS, IN CARPET, COMING OUT OF LIGHTS AND
DAMAGE TO WALLPAPER ETC / REPAIRED AND REPLACED CEILING AND REPAIRED WALLS AND
TRIMMED OUT / MOISTURE TESTED ALL OF COACH
2254 BATTON CLG PLSTC 99 1.000 EA 0.00 0.00
0150 $920.00 NO CHARGE WORK DONE AT RE 1.000 H 0.00 0.00
$920.00 NO CHARGE WORK DONE AT RED BAY BODY SHOP / LS ROOF RAIL, LS AWNING RAIL, RS ROOF
Terms
Pay immediately w/o deduction
TIFFIN-EMPLOYEE
TAX 0.00
Total Labor 0.00
Total Parts 0.00
Total 0.00
DURING TEST
WH
903209000 KW
LEVELING
OZ SAU
BRIGHT WH
CVR
14 TO
50.000 EA 0.00 0.00
POLYSTYRENE FOA
1.000 EA 0.00 0.00
48X99
3.000 EA 0.00 0.00
ANTENNA
1.000 EA 0.00 0.00
BRIGHT WH
19.000 EA 0.00 0.00
Terms
TIFFIN-EMPLOYEE
TAX 0.00
Total Labor 0.00
Total Parts 0.00
Total 0.00
38,783 PostsLatest Activity: Sep 09, 2026
