just_justin
Sep 14, 2019Explorer
DrewE wrote:
If you're happy with the price and the seller is happy with the price, then it's hard for me to say it's not a good price. Very much of the actual value of a used RV depends on its condition, which is pretty much ignored by the NADA numbers. Prices also vary quite a fair bit geographically; finding a decent used RV for $10K would be pretty hard in New England, from what I've seen. Well kept, practically no water damage, everything works properly...that's worth some money; and if your needs or wants are rather unusal and specific, you may have to pay more to get them met.
Be extremely careful with your towing decisions. The diesel engine doesn't change the brakes, the frame (and frame extensions), the hitch, etc. I'm not really sure it even would do much better in general with towing than the V10, though it will be running at a lower speed and hence sound "better", or at least different.
A fair few newer Ford class C's have 7500 pound tow ratings, by the way.
There will be trailer brakes, it has a controller and as far as the frame/extensions, that's why I wanted a 450, frame is 1 piece all the way back....there are no extensions, 350s stop right behind axle and the rest is pretty much body. The towing capacity and therefore GCWR is determined by the engine, trans and rear axle/gearing. An E450 with the 7.3 can most certainly tow more than an E450 with the V10. Motorhome or not...
38,768 PostsLatest Activity: Jan 26, 2021
