Rick_Jay
Sep 15, 2019Explorer II
just_justin,
I just want to make sure you have the right info while you're making your decision.
Frame Extensions: I believe all of the longer E-450 RVs have frame extensions behind the rear wheels over the stock chassis. There may or may not be extensions to lengthen the wheelbase. The E-450s may not require the extensions to lengthen the wheelbase, but there most likely are extensions behind the rear wheels.
The towing capacity is what the manufacturer says it is. Engine, transmission & gearing are part of the equation, but frame, brakes and suspension considerations may come into play as well as the actual hitch rating. To the best of my recollection, the diesel E-450s were rated EXACTLY THE SAME as the V10 E-450s as far as towing capabilities were concerned. Again, going from memory, they were 14,050 pounds GVWR and 20,000 lbs. GCWR for the E-450's.
Like I said, the diesel might give you a better towing "experience" in some situations, but that's about it. The numbers don't improve, other than perhaps MPGs. BUT, the fact that it comes with a propane generator would kill it for me. You'll be stopping for propane every trip so you can run the generator while travelling down the road to keep the AC cranking. Not worth it for me, which is why we stopped looking at the diesels back in our day.
As others have said, though, you seem to be sold on it, so hopefully it meets your expectations and then some! :)
~Rick
just_justin wrote:
and as far as the frame/extensions, that's why I wanted a 450, frame is 1 piece all the way back....there are no extensions, 350s stop right behind axle and the rest is pretty much body. The ...towing capacity and therefore GCWR is determined by the engine, trans and rear axle/gearing. An E450 with the 7.3 can most certainly tow more than an E450 with the V10. Motorhome or not...
~Rick
38,783 PostsLatest Activity: Sep 23, 2026
