MrWizard
Mar 11, 2017Moderator
where the scissors cross each other ?
thats a hinge point, should be harden metal
get a high graded 'carriage' bolt
grind down the square area under the head to where IT is round
install with head on the outside (hopefully doesn't hit anything when closing), nut on the inside, cut off flush, ground head flat if needed
