Travelin2
Feb 13, 2017Explorer
DrewE wrote:Travelin2 wrote:
I'm not sure about the venting of the tank and am a little nervous about pumping into the tank anyway until I know how it's vented. I'm sure it is, I just don't know where it is so I can watch for it to start spitting when the tank is full.
I would be shocked if the vent/overflow outlet isn't someplace underneath the motorhome. It certainly is on my Coachmen motorhome. Once it starts piddling on the driveway, I turn off the water hose. It would make no sense at all to vent it somewhere that water spitting out would be reasonably expected to cause trouble, such as inside somewhere, since filling or even sloshing after the tank is full could cause some water to burp out.
I removed the top of the dinette bench to check out the vents and where they exit the coach. There are actually two and they exit between the chassis frame rails.
38,778 PostsLatest Activity: Jun 04, 2026
