alliemac9
Feb 13, 2017Explorer
Travelin2 wrote:DrewE wrote:
It appears that the right hand valve is between the pressure side and the tank inlet, i.e. the fill valve. The left hand valve apparently selects where the hose inlet and pump inlet hook up. I would try the left valve in the winterize position and the right valve in the fill position -- i.e. both valves pointed at each other. It may not work.
Another method for getting the bleach solution into the tank that many people use is to set the valves to fill, pour the appropriate amount of bleach (undiluted) into the far end of the hose, and then hook it up to the spigot and fill as usual. The bleach will dilute properly when the tank is filled. The short burst of undiluted bleach won't harm the plumbing or hose in any way, though it might not be a great idea to let it sit there for hours or days on end.
Well Drew, I'm not sure how you deduced that the levers need to be pointed at each other to suck water into the winterize port and put it in the holding tank but that is the correct setting.
I played around with the valves this morning and found it works fine. The designers of the user instruction panel just didn't make it clear enough for some of us dunderheads. The position indicated for using water from the tank or city water is correct. The position indicated for winterizing, sucks in through the winterizing port and puts it directly into the plumbing system so you can turn on each faucet till you get the pink stuff but does not fill the tank. For that to happen the levers need to be pointed at each other and then fluid is sucked in through the winterizing port and straight to the freshwater tank. The only snafu was that they didn't indicate that on the instruction panel. Drew was able to figure it out and I had to use trial and error. I guess if I need to figure something out about dynamite, maybe I better call Drew.
Wow - I am so excited to try this on my rig! I have the exact same water panel (same graphics and knobs; I've seen a few variations from Coachmen) and I could NOT get mine to suck anything up, either. I've always used the "pour bleach into the hose" trick. But, I thought it would be cool to have a backup plan to suck water from a jug to refill the tank while boondocking, if I wanted (i.e. these coaches have no option for gravity fill, so without a pressure hookup I cannot add water to my freshwater tank which hasn't been a problem for me yet, but seemed like an oversight relative to other coaches). My local Coachmen people thought I was insane when I brought the manual in and said "it's supposed to suck water in" (either for winterize or non-pressure fill) and told me the valves/plumbing were not set up to accommodate that and it was a generic feature in the manual that didn't apply to my rig. Maybe they were wrong! I need to print this out and do some testing!!!
And if it works, I'll take a sharpie and draw an additional configuration on the inside of the panel door or on the panel itself (I wrote inside the door the volume of bleach I need to use to sanitize my system so I don't have to look it up and calculate every time).
Thanks, Drew! And thanks Travelin2 for asking the question and clarifying the function of filling the lines versus the tank! I never tried opening the faucets to find out it was filling the lines when in Winterize mode.
Super excited!! :)
38,779 PostsLatest Activity: Jun 16, 2026
