oz20x6's avatar
oz20x6
Help with furnace please
Hello. We have an atwood AC-1511 system. The thermostat does not go below 60 degrees. We will be encountering 25-40 degree F weather and we don't want to burn through our propane but also don't want our coach to go below ~45 degrees. Is there a way to set it below 60? Also, in the manual it says: "the unit will heat in the heat pump mode in ambient temperatures above approx 45 degrees f. The furnace with automatically engage at ambient temperatures below approx 45 degrees." What is a heat pump, and what do we need to do to ensure the automatic 45 degrees furnace turn on? Thanks guys i really appreciate your help!
Also, we are new full-timers, been in our RV about 3 months now! :)
