KD4UPL
Feb 17, 2018Explorer II
If you have a true 3 way ref. that runs on 12v directly you can use that while traveling if you want. Most people just use propane while traveling. Some refigerators are only 2 way and don't have a 12v only option. Either way, you will need to leave your battery turned on, the refrigerator needs 12v to run the control board even when being fueled by propane. Your propane tank will last a long, long time running just the refrigerator, likely several months.
