dougrainer
Aug 12, 2016Nomad
Monaco did not connect the refer to the Inverter. They DID connect the Inverter to the refer Icemaker. So, if you want the refer to run off Inverter, access the outside access door and you will see 2 -120 volt receptacles. Usually, Monaco labeled each Receptacle. INV on one. Use the INV and plug your refer cord into that. You may have to use a 1 to 3 plug in adapter as some of those receptacles do not have 2 plug ins. Doug
Norcold 1200 model is what you should have. Monaco optioned Norcold refers with 2 power cords to run the Icemaker seperately from the refer for the Inverter
