JFNM
Aug 12, 2016Explorer
Howdy Tinstar, most coaches are not wired to power the refrigerator from the inverter as the load on the batteries would be very high.
Couple other things. I am told (not an expert) that having a very high load items operating when the generator is started/shut-down is very hard on the generator electronics. Obviously you can't help it when it shuts itself down.
Occasionally this 'shuts down after 5 minutes' issue is an oil problem (too little) or overheating. The latter may be due to a faulty temp sensor. Your generator is likely giving you a fault code when it shuts down via the light "in" the on/off switch.
