dougrainer
Aug 13, 2016Nomad
Tinstar wrote:dougrainer wrote:
Monaco did not connect the refer to the Inverter. They DID connect the Inverter to the refer Icemaker. So, if you want the refer to run off Inverter, access the outside access door and you will see 2 -120 volt receptacles. Usually, Monaco labeled each Receptacle. INV on one. Use the INV and plug your refer cord into that. You may have to use a 1 to 3 plug in adapter as some of those receptacles do not have 2 plug ins. Doug
Norcold 1200 model is what you should have. Monaco optioned Norcold refers with 2 power cords to run the Icemaker seperately from the refer for the Inverter
There are two plugs in the access panel. The fridge is plugged into one (top outlet) and the ice maker is plugged into the outlet which is mounted 3 inches or so below the other. I assume Monaco wired the ice maker like you said and it is running from the inverter.
If the genset doesn't work when I leave Sunday and since my engine will be running and charging and I have about 400 watts of solar, do you think it would be OK to run the fridge from the inverter. It would be for about a two hour trip. If not I'll eat and drink everything in there. :E
Well, Since we sold and I serviced Monaco's from 1997 until 2008/9 when they went under, You can BET that the 120 is wired like I stated. Now, for what they "draw" on 120. A 1200 will pull about 400 watts when on 120. Since you probably have at a minimum 2000 watt Inverter, there is no reason NOT to run on 120 in transit. The Chassis Alternator has more than enough power to supply the 12 volt DC amps to run a 400 watt appliance. They are DESIGNED to run appliances like refers when in transit. Doug
