dougrainer
May 15, 2020Nomad
rgatijnet1 wrote:dougrainer wrote:
Per the Instructions, IF YOU DO NOT USE THE TRIGGER HARNESS(connecting the trigger wires) THE TURN SIGNALS SHOULD NOT AFFECT THE OPERATION. If the Camera's have there own 12 volt supply and not connected to the original Furrion harness, the system should operate as the OP desires. You do NOT have to use the Trigger harness for install. Doug
Well then they should be working, right???? :B
That is why I asked the OP those questions. He has not responded. I HAVE installed the Furrion 3 Camera RF systems on both Trailers and Motorhomes and at no time did the original turn signal trigger system on the original motorhome system affect the operation, because I made sure the side Camera's had there own 12 volt supply. Doug
