Mich_F
Jul 29, 2014Explorer
Those 3 empty slots could be for 3 extra circuits. Just look on the cover for the fuse panel under operation guide - DC distribution panel - it will tell you what each fuse/circuit controls.
Normally most coaches have a switch mounted by the door which controls the overhead light closest to the door. The light can usually be turned on or off on the light itself. So it has to be set right to work properly. Many MHs have overhead lights that have switches only on the lights. Check the bulbs - they could be part of your problems.
38,777 PostsLatest Activity: May 20, 2026
