AJR
May 16, 2020Explorer
My current rig (see sig.) takes up two diagonal parking spots in any shopping center I have been too. It is not hard to maneuver around.
I would not be overly concerned about mileage. How the rig was maintained and what weather conditions it was driven in are more important I think. The big issue for me is was it driven allot on winter roads that were salted. If you look underneath the unit you can determine that.
The larger the holding tanks for fresh water, gray & black water the better.
Things to look for I have found value in while having in a class C ….
Walk into shower. Some showers you have to step up to get into them.
Corner shower, some are bigger than others. Big ones are real roomy inside.
Counter space by the kitchen sink for food prep.
Large outside rear storage. They can be up to 100cu ft.
No window over the headboard of the bed.
Livable with slide(s) in.
A north south bed that is offset to one side. That gives you room to walk & dress on one side.
60x80 real queen bed. Uses standard bed sheets and such.
Ford E450 or Chevy 4500 chassis. As a Ford guy, I have found the Chevy better. Hate to admit that.
Just a comment. All class Cs have an overhead above the cab designed to be a bed or audio center. It is a great place for storing things. My current rig has lots of storage behind the TV in the overhead area.
38,770 PostsLatest Activity: Apr 12, 2026
