topless
Jan 23, 2015Explorer
You should have load range E tires on you van. They should be equipped with high pressure tire valves. Those tires will have a pressure rating of 80 psi. You don't say what tire pressure you are running, but on my high top van I run 79 in the rear and 65 in the front.
The rv converter recommended 79'rear and 55 front, it handled like a pig in wind and was flat out scary on a 2 lane hi way with a cross wind and an an 18 wheeler went by. I was going to install anti sway bars until someone recommended raising the front tire pressure.
60 helped, 65 changed everything.
Make sure you have the correct tires and try increasing tire pressures before you spend a bunch of money on accessories.
