Diplomat_St_PooExplorerNov 30, 2016Hit my mirror. Need help removing mirror housing.After 10 years I finally did it. Got to close to the MH garage post. The mirror is screwed into the MH body from the mirror side. I'm having trouble figuring out how to remove the housing from the...Show More
dougrainerNomadNov 30, 2016You remove the ARM from the wall mount(bottom bolt). Then, the Black Plastic housing will pop off and expose the 4 mount screws. Doug
Related ContentHouse battery drainStaple RemovalVelvac mirror removalRamco Mirror - unable to removeinterior mirror removal
