dougrainer
Nov 30, 2016Nomad
Diplomat_St_Poodles wrote:Ivylog wrote:
Remove the plastic plug on the bottom exposing the bolt that holds the arm on. Remove the arm and unplug the wires. The cover will slide off exposing the four wood screws that hold it on. You may be able to use larger screws, even drilling the holes in the alum base larger. You can use bolts but getting a washer and nut on will take someone with long arms.
There are no plastic plugs at the bottom of the base. It is one solid unit. Hopefully when I get the arm off I will be able to slide the housing off.
I can remove it from the MH but I will still need the housing removed from the base to screw it back onto the chassis.
There SHOULD be a plastic plug directly below where the arm is mounted. You remove that round plug and that gives access to the 9/16 inch bolt head you remove to take the arm off the mount base. Doug
38,782 PostsLatest Activity: Sep 02, 2026
