RoyB
May 24, 2015Explorer III
My assumption was apparently wrong - You will need to install a couple of batteries in your van and purchase a 300WATT PSW INVERTER to be able to do what you ask.
You will also have to watch your battery charge status and if you drain them down below 12.0VDC and not recharge right away they will not last very long. i.e. you will need to come up with a good way to re-charge your batteries.
What you don't want to do is tap into your VAN START BATTERY system otherwise you will run it down and be stranded somewhere and probably have to replace that battery as well...
You need a PLAN B called a small generator
Roy Ken
Roy Ken
38,769 PostsLatest Activity: Apr 03, 2026
