sammytoo
Feb 18, 2017Explorer
Travelin2 wrote:ppine wrote:
Drain your water tank after each trip.
I don't drink out of the tank. I use water containers for drinking water.
That's too bad that you can't see your way clear to use your freshwater system as it was intended. If you sanitize the system and fill with clean water, then it is perfectly safe to use for drinking. If you want an eye opener, you should have a look inside any public water storage tank and the plumbing or check out the inside of your well casing when you change out your well pump. If you want a confidence builder, take a water sample from your RV down to your county water dept. and have it tested. I think you will be pleasantly surprised...Good luck and all the best.
X2
38,769 PostsLatest Activity: Dec 31, 2014
