Photomike
Feb 18, 2017Explorer III
Travelin2 wrote:
That's too bad that you can't see your way clear to use your freshwater system as it was intended. If you sanitize the system and fill with clean water, then it is perfectly safe to use for drinking. If you want an eye opener, you should have a look inside any public water storage tank and the plumbing or check out the inside of your well casing when you change out your well pump. If you want a confidence builder, take a water sample from your RV down to your county water dept. and have it tested. I think you will be pleasantly surprised...Good luck and all the best.
I don't have a problem using my on board water. After servicing commercial ice machines and seeing what happens at hotels with cleaning glasses with dirty towels I feel that my RV is WAY cleaner! Plus if I fill up at home then I have my home water for many of my shorter trips and I feel this is better than getting water on the road.
38,777 PostsLatest Activity: May 24, 2026
