dougrainer wrote:
azdryheat wrote:
Normally there is only pressure when work is being done such as moving the slide in or out. When at rest there is no pumping action and zero pressure.
Crack open any of your Slide room hoses connections. You may want to rethink your statement. ALL Hyd slide rooms have static pressure whether extended or retracted. Depending on the Brand of Jacks, they may have pressure when retracted. Dextron 3 is the fluid for all motorhome Jack/slide systems. Doug
Thanks they are Lippert..
