rgatijnet1
Apr 24, 2017Explorer III
colonelcorto wrote:
It is located where it gets ambient air from the front grille in front of the condenser. There is about 18 inches between the cooler and the grille. Its only about 12 inches by 9 inches in size. Would moving it closer to the grille help?
When you go slow, during a climb, there may not be enough air movement to provide sufficient cooling. I would replace that cooler with a larger one and add an electric cooling fan that you can switch on manually if the temps start to climb. Get one rated for 30,000 pounds GVWR.
