RLS7201
Apr 24, 2017Explorer II
200 degrees is pretty much normal and acceptable for that transmission. The reason it heats when going down hill is because the torque converter unlocks when you tap the brakes. Under normal pulling conditions, the torque converter stays locked until you drop in to 1st gear.
My 95 Bounder 460/E40D runs the same temperature range as yours. Mine was still working well at 140,000 miles but was pulled for rebuild when I put in the new stroker engine.
Richard
Richard
