rgatijnet1
Apr 26, 2017Explorer III
The main thing you need to find out is where the fluid temp sensor is located. The hottest place for your fluid is at the output from the torque converter. One of the cooler places is in one of the transmission lines coming from the cooler or in the pan itself.
Depending on where the temperature is being taken, your fluid temperature coming out of the torque converter could be much higher than the 200 degrees that you are seeing.
