xpjet96's avatar
xpjet96
Hot Water Engine Heat Exchanger
I have a water heater that uses an engine heat exchanger to heat the water while driving down the road. Access to the water heater is not insulated inside the cabin due to access requirements. Problem is that while driving in warmer temperatures (near 100 degrees in Iowa and South Dakota last week) heat is emitted making it difficult to get the air cool in the cabin. I like the feature, but would like to know if there is a bypass in the engine compartment or at least a way to add one. Can't find any reference in the manuals.
  • No valves on the coolant lines to/from water heater.
    You could add one on coolant line to water heater and shut the flow off.
    Just valve it in when you want to take advantage of that free heat
    AND remember that both lines would still have coolant in them IF you did any work on water heater that required disconnecting them at the heat exchanger tube.
