Old-Biscuit
Oct 06, 2013Explorer III
3 valve system
One type of 2 valve system....cold water inlet valve (bottom) is a 2 position valve
Another type of 2 valve system.....hot & cold valves are 2 position valves
Now if you are actually talking about a 'water filter'......then 1 valve is inlet, 1 valve is outlet and the other valve is 'filter bypass' so that cold water can still flow with filter bypassed to replace/clean/repair etc(Close inlet/outlet & Open bypass)
38,776 PostsLatest Activity: May 14, 2026
