janstey58ExplorerNov 18, 2016Hot Water Heater Check Valve FailureHi All, I was starting to winterize my MH last night, and had the H2O heater drained with the plug out. I started to pump anti-freeze into the plumbing via the winterizing bypass tube, and noticed an...Show More
donn0128Explorer IINov 18, 2016Actually it will impact future use. Replace it. It is going to be in the top port.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Water Pump Failure Traveling To The Eclipse
