janstey58ExplorerNov 18, 2016Hot Water Heater Check Valve FailureHi All, I was starting to winterize my MH last night, and had the H2O heater drained with the plug out. I started to pump anti-freeze into the plumbing via the winterizing bypass tube, and noticed an...Show More
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Water Pump Failure Traveling To The Eclipse
