Took my RV out for our first trip and couldn't get the hot water heater to work on electric, it worked fine when I fired up the LP but not on electric. Checked the breaker, any other idea's??
IF it's a Suburban look for an ON/OFF switch in outside compartment in corner
IF it's an Atwood look for an ON/OFF switch on box that is located on the backside of WH. (inside rig) Some earlier Atwoods used a local switch vs panel mounted
