Hello I have a 1996 Monaco Dynasty. Does anyone know the steps to turning on the hot water heater using electrical while on shore power and also steps using propane? Thank you in advance.
If it is a Suburban water heater there may be a switch outside on the water heater itself. Remove the outside water heater grill/cover and look at the lower left hand corner of the water heater for a small rocker switch. That is the only way to turn mine off/on on electric other than using the circuit breaker as an on/off switch, not something they are really intended for.
