nomad297 wrote:
MrWizard wrote:
put fuel in the RV and drive to a warmer climate :B
NO. its not maint issue..its the cold water comming in from city inlet
fill your fresh tank, turn off the city inlet connection
once the fresh water tank warms up..(24hrs) the showers will last longer
as you will be mixing less hot water
also i would switch to LP
its cold you are going to need it
i would rather pay for LP and have hot showers, than worry about running out of hot water
This is the problem.
I am a plumber and every year as the service water gets colder and colder, we get more and more calls from people thinking their water heater is going bad. I could take advantage of this and sell a load of water heaters every fall and winter, but I am an honest plumber.
Bruce
I'm not buying this answer. Water lines are buried in the ground below the frost line, therefore the water temperature for city water will be the mean ground temperature for your area plus or minus a degree or two. Not enough to make a difference. Check your heating elements and or the temperature controller.
