bhivetravels's avatar
bhivetravels
Hot water not lasting
Last few days our hot water is not making it through two showers (10 gal). It used to easily handle the two showers ... If I switch on the propane it will make it, just not while on electric alone. Is there anything I can do maintenance wise to fix this?
  • put fuel in the RV and drive to a warmer climate :B
    NO. its not maint issue..its the cold water comming in from city inlet
    fill your fresh tank, turn off the city inlet connection
    once the fresh water tank warms up..(24hrs) the showers will last longer
    as you will be mixing less hot water
    also i would switch to LP
    its cold you are going to need it
    i would rather pay for LP and have hot showers, than worry about running out of hot water
