How_Dun's avatar
How_Dun
hot water runs hot then cold
We left the Midwest this morning with a winterized 2008 Newmar Dutch Star. We are far enough South to have water. The problem is the hot water in running from the faucet first hot and then cold. I have tried everything I can think of and still am not getting hot water only. What am I doing or not doing and what can be the problem? Thanks for your help.
  • Old biscuit called it. We have the Atwood XT with mixing valve. Can it
    be repaired or must it be replaced ?
  • Do not repair or replace it. They are a disaster and useless.
    Just remove it out of the plumbing and go direct. We did this
    6 years ago and never a problem.
    This is a very bad idea. The water temperature in this XT water heater is 155-160 degrees. It will cause serious skin burns in a matter of seconds.
    They are better replaced. I doubt you could clean one out and then get the mixing valve to function correctly. The purpose of the XT series with the Mixing valve is to produce 16 gallons of hot water from a 10 gallon tank. DO NOT REMOVE IT. As Jetcare stated you will have extremely HOT water without the mixing valve. The normal temp of a RV water heater is 130 degrees. As Jetcare stated, the XT produces 160/170 degree water which is way above scalding temp. The Mixing valve takes that extreme hot water and mixes it with cold to produce 130 degree water output. Doug
    It can be soaked in CLR....sometimes that works, most times not so much
    You can replace with OEM roughly $145...LINK
    Do an Internet Search for a mixing valve.
    Your OEM one uses 1/2" and is set for 130*F output
    OR
    Remove it completely.
    Just change plumbing to COLD water IN (Bottom) and HOT water OUT (Top
    Then change normal t-stat form the OEM 160*F to the 140*F t-stat used on all other models.(Atwood 91447)
    Will need to change connection on brown wire from t-stat to a spade connector....XT uses a PIN connector
    Removing it, changing plumbing (easy) and changing to lower temp t-stat is cheapest option AND no more mixing valve to plug up.
    Downside......your 10 gallon water heater that was equivalent to a 16 gallon WH due to the higher water temp is now just a regular 10 gallon WH-------BUT no more mixing valve issues
  • It started working on own. Road conditions shook it loose. thanks for all your help.
  • My coach had the same problem and I traced it to the Watts mixing valve. It was soldered so you could adjust it, I knocked the solder out and had my wife stand by the sink with a thermometer while I adjusted to the proper temperature. Been working good for about 5 years now. If you feel that's to risky I would replace the mixing valve.:)
  • I removed my mixing valve and soaked it in CLR for a day then re-installed it. Been working great for 4 years. Probably due for another cleaning soon.
