revumpExplorerApr 20, 2014Hot Water TankI am an 06 Alfa See Ya. It looks like my water heater is leaking from the bottom. The hoses look dry. Does it need to be replaced and if you have done this what did you replace it with?
chuckftboyExplorerApr 20, 2014If you need to replace it go with the same make and model. Thats usally the fastest and easiest way
Related ContentNo flow from hot water tank Nautilus P1 systemWater tank won't fillDraining hot water tankhot water tankHot water tank drain plug
