revump
Apr 20, 2014Explorer
Hot Water Tank
I am an 06 Alfa See Ya. It looks like my water heater is leaking from the bottom. The hoses look dry. Does it need to be replaced and if you have done this what did you replace it with?
path1 wrote:It is hard to see back there when mine was leaking I put a paper towel under the fittings for the inlet and outlet when I saw the towel wet I tightened the fittings and all was well again.
Leaking from bottom of tank or bottom of rv??? Make sure.
Mine was leaking at the water connection at the tank and running down to bottom, but when looking at it from the side it sure looked like WH was leaking from bottom.
Confirm where leak is before buying new. Might just be twist of connection.
