captron33
Jun 30, 2018Explorer
Hot water
2006 travel supreme, ...just starting a trip and no hot water at the spigots,shower anyehere! The tank is heating, i have opened the relief valve at the top of valve and cycled the bypass valve, no h...
Old-Biscuit wrote:
As suggested .....
Check Valve in Hot outlet on WH Tank (Top Fitting) is clogged/failed
No mixing valve or you would get cold water flow when hot clogged
