captron33
Jun 30, 2018Explorer
Hot water
2006 travel supreme, ...just starting a trip and no hot water at the spigots,shower anyehere! The tank is heating, i have opened the relief valve at the top of valve and cycled the bypass valve, no h...
malexander wrote:Old-Biscuit wrote:
As suggested .....
Check Valve in Hot outlet on WH Tank (Top Fitting) is clogged/failed
No mixing valve or you would get cold water flow when hot clogged
I would get the flow to the trickle then nothing. It WAS the mixing valve. Enough water would trickle through to pressure up when the faucet handle was turned off. Then when turned of it would run a stream down to nothing. Mixing valve was stopped up. I did all the repiping myself, removing the valve. Haven't had one iota of a problem since.
