ferndaleflyer wrote:
Well here we go---I owned a garage/repair facility for 40 years and its not the batteries, but I am far from well versed on these DP even if I have had this one for 15+ years SO, If there is a cut off switch I have never used it and I don't see it mentioned in these drawings. If this is the same as a disconnect relay I still don't know where it is.....at least you all are trying, thanks......No converter as I removed that years ago.
Only thing I can suggest is to find the "Salesman Switch" that might be the issue - Just a guess.
But I really don't know that much - Forgot most of the little bit I ever learned.
JMHO,
