dougrainer
Nov 23, 2018Nomad
JaxDad wrote:dougrainer wrote:
1. When using the RV you NEVER have the Coach or Battery disconnect OFF. WHY would you have it OFF?
Doug
The OP clearly said in a short concise post “If I go into motorhome, and toggle the use/store switch from use, to store, then back to use, I get 14 volts to house batteries.“
Offering advice works better when you reply to what they said, NOT what you think they said.
My advice is spot on because there is no way to determine IF the OP understands HOW his disconnect system works. The fact he toggled from use to Store back to use means NOTHING. He may have NOT had it in USE position to begin with. That is why I asked for clarification from the OP. Jerks like you make forums a pain sometimes. You don't like me? DON'T RESPOND TO MY POSTS! Doug
