MDKMDK
Feb 26, 2018Explorer
When you post up a question about your rig, it's a good idea to post the year/make/model as well. Helps the troubleshooters.
In most class C/A motorhomes, the power step runs off the chassis battery.
Also, in most motorhomes, the shore power and generator will "light up" the coach without the batteries, so that's why it works when either of those two conditions are met.
Try this. There's a switch to enable/disable your coach batteries, sometimes located just inside the side entry door beside the inside step well. Check to see if that's in the "enabled" position. There may be a little green light on when it's in the enabled position.
Have a look, and post up your results.
