Artum_Snowbird
Apr 23, 2018Explorer
In every circuit there is a feed out and a return. Try taking your jumper cable, connect to battery negative, then to the negative terminal on your converter panel. If that makes things work, its your negative return. Look for a loose connection. If that doesn't help. Try the same with the positive cable. If that makes it work, then it's the positive. It's a process of elimination.
