PawPaw_n_Gram
Dec 09, 2013Explorer
fighterpilota wrote:
After being hooked to shore power the volt reading at the battery terminals is 14.2 volts which seems like too much. ????
No.
The only way you can truly tell if a battery is fully charged is with a hydrometer.
What does the voltmeter read three hours after the charger has been turned off and there has been no load is on the battery. That's the only valid way to get a reading with a voltmeter on a battery charge.
38,768 PostsLatest Activity: Jan 26, 2021
