tenbear
Nov 17, 2013Explorer
If you have a voltmeter measure the battery voltage at various times. That way you can tell if it is getting fully charged. Depending on your converter, it could require much more than 5 hours to fully charge the battery.
You can probably find a convenient place to measure the voltage at the power distribution panel. Make sure you are measuring the 12 volts, not the generator output of 120V. Usually the 12v power uses fuses, the 120v uses circuit breakers.
38,782 PostsLatest Activity: Sep 02, 2026
