Matt_Colie
Nov 17, 2013Explorer II
Wendyshieh wrote:
I run the generator for 5 hours during the day( from 11am to 4:00pm) hoping I would have enough power to kick off the heater at night to keep me warm. No, by 7:00pm, my coach battery is very low. Generator won't even start, I need to start the coach car engine to start the generator.
Is this ok?
Does my coach battery is bad?
Unable to store power?
How long do I have to run the generator?
How do I prevent the coach battery discharged so quickly?
Thanks for your input in advance.
Wendy,
You asked five questions and were very short on providing specific information.
1 - Maybe....
2 - Maybe....
3 - Possibly
4 - Depends...
5 - Don't run the lights or heat.
More about:
1 - Without knowing what you house bank is and how old it is, there is no way to give you a meaningful answer.
2 - You can take to a auto parts store and they can try to test it, but their test is for starting load and not total capacity and that is your real issue here.
3 - You can determine this to some extent on your own. Leave the coach on shore power for a day so the house bank is charged, then if you have a volt meter - installed or portable, read the voltage and turn on the heat. When the voltage gets to 11.5, you are done.
4 - If the battery is down to 11.5 or less, and you do not have a smart converter/charger, it could take a day (yes - 24 hours). If you have a very large (a relative value) converter/charger and the house battery is still pretty good, you could get it from dead (5% charge) to 90% in as little as six hours.
5 - You will have to find out how much power different things draw and decide what to leave off and even then, you may not be able to overnight with the heat going.
I suggest that you find out what your battery capacity is, how much load the things you run are and then do some more reading on caring for batteries.
Matt
38,782 PostsLatest Activity: Sep 02, 2026
