Gjac
Apr 03, 2018Explorer III
How did you determine the house batteries were dead? Did you check them with a volt meter? If so what was the reading? With the MH plugged in take a reading across the pos and neg terminal of the battery, you should read something greater than 13 plus volts, if so you know that your converter is working. Unplug the MH from shore power and check the voltage across the pos and neg terminals, the next day, you should read about 12.6 volts if battery is good and connections are good. If you do this simple test and post your results here I am sure your issue will be solved. If everything was good when you bought it and this issue just happened in the last several weeks it is probably something simple.
