klutchdust
Dec 11, 2018Explorer II
CharlesinGA wrote:
Steps operate off of the chassis/engine battery and is protected by push to reset circuit breakers. Chassis electrical box is found behind a labeled panel in the back of the front RH storage compartment (basement storage) Panel has two T knobs to release it and expose the breakers. Slide breakers are in there also and it too is off the chassis battery, NOT the house batteries.
Charles
found them and also behind the cover is some more fuses that one would not normally know existed. All checked out ok.
this was the culprit, broken wire on the magnetic switch.
