supercub
Feb 03, 2015Explorer
House Water Pump Follow Up
Finally at a place where I could remove the cover and see the pump. Everything appears to be ok. I ran it and it makes a terrible rattling noise. Isolated hoses and noise/rattling never changed. I took off the line that goes into what looks like a clear plastic filter. Hooked it back up and now the pump runs, even not pumping water, It will run, extremely slowly, but will run. I shut the power off and then back on, and it won't start up......but then as soon as I turn water on, and it stays off, like it should till I put a demand on it, by turning the water on, but then I turn the water on and and then back off......it will run at very slow speed. It's a Remco 55 Aqua Jet. I just bought this motorhome about 8 months ago. The date on the pump is 2-13.....so it's not very old. Thanks
Brian
Brian
