OFDPOS
May 19, 2015Explorer
JD was in the area visiting family so we sent some PMs back and forth and he offered his assistance to help me put the sway bar on.
I gladly took him up on the offer.
First impressions after installing Hellwig rear sway bar.
Had a couple hic-ups on the installation, but we figured what we did on mounting a couple brackets was right, instead of what it showed in the instructions
Noticed a little difference when I stepped into the MH it didn't seem to drop as much .
Tried to do the stand over rear axle inside and rock back and forth but couldn't really get it to rock very much..
On initial road test noticed it stayed true taking a couple corners.
JD commented it seemed to go right around the corner not swaying .
Over all the install went well , real test will be both when the DW gets in and sits at the table doing her make-up and get out on the freeway and pass/get passed by some semi's !
It was nice meeting JD putting a face to member here and with his help we got the sway bar on fairly easy.
