bukhrn
Jan 27, 2014Nomad
ron.dittmer wrote:X-2, as it happen every once in a while, with hurricanes, tropical Storms & Ice storms. ;)
For the Ford E350 and E450 chassis since the Triton engines were introduced, I believe the "Built-For-Motorhome" cut-away chassis has the 55 gallon tank standard as is the 6.8L-V10 engine. But that chassis can be ordered with the 5.4L-V8. It could be that if your rig has the V8, you have a smaller fuel tank. I never heard of a V10 with the smaller tank.
If your motor home has a generator, the larger fuel tank is much better to provide longer generator run times. I personally appreciate having at home, a mobile power station with a lot of supporting fuel, just in case of a long term power outage at home. On trips, I rarely get below a half tank so I am just carrying extra weight. I suppose I could fill the tank to 3/4 but I appreciate the peace of mind. On one trip, our generator would not run because we got to that point where the tank was at 1/4 full. It was actually a little higher than 1/4, near 3/8 full.
38,777 PostsLatest Activity: May 24, 2026
