Rich_D_
Mar 08, 2013Explorer
ivylog said: "(had a 98 Patriot) so I know a lot about CCC, GVWR axle weights. The only reason you have 3K of CCC is because Beaver put a 23K rear axle instead of the normal 20K axle (max legal weight in most states) SO, there is NO way you'll be able to put a lift on the back of your rig."
While I agree 100% that overloading the rear axle is a concern, what state still has a 20K limit on a rear axle for a MOTORHOME? Exemptions are in place for most, if not all states or every bus and large DP would be illegal to operate.
